[postgis-tickets] [PostGIS] #2363: st_distance with an added Integer value is not working in 2.0
PostGIS trac at osgeo.org
Tue Jun 18 12:56:24 PDT 2013
 Reporter:  vbalent  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by vbalent):
 I did check the nadgrid files and they are both reporting the exact same
 return values in Windows Server and Linux.
 I am trying to keep this simple for now the SQL statement below, however
 The st_distance worked perfect from above, I know it does not utilize the
 Gist.
 But it works on Windows Server and not on Linux.
 This SQL statemant errors but I can not find a Sample code where I can say
 =5280 feet for a Mile Radius.
 SELECT * FROM PART_1_CRIMES
 WHERE ST_DWithin(geom, 'POINT(687884 1355669)', 2260)
 =5280.0;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2363#comment:3>
