[postgis-tickets] [PostGIS] #2339: PostgreSQL 9.3beta1 EDB regress failures
PostGIS trac at osgeo.org
Tue Jun 18 19:12:32 PDT 2013
  Reporter:  robe      |       Owner:  robe
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.1.0
 Component:  postgis   |     Version:  trunk
Resolution:  fixed     |    Keywords:  windows64,edb
Changes (by robe):
  * keywords:  => windows64,edb
  * status:  new => closed
  * resolution:  => fixed
Comment:
 Yippie -- building against mingw64-gcc 4.8.0 with seh makes regress
 against EDB 9.3beta1 64-bit pass all regression tests.
 I'm building up a new ming64gcc48  and will use that on winnie to build
 the 9.3s from now on (but will keep my original ming64 until I switch the
 others to use the new chain since the chains are incompatible).  So I'll
 close this one out and reopen a separate buildbot ticket.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2339#comment:4>
