[postgis-tickets] [PostGIS] #2365: find_srid performance regression with large numbers of tables
PostGIS trac at osgeo.org
Wed Jun 19 19:10:12 PDT 2013
 Reporter:  angrygoat  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  low        |   Milestone:  PostGIS 2.0.4
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
Changes (by dustymugs):
  * milestone:  PostGIS 2.1.0 => PostGIS 2.0.4
Comment:
 I suspect the long-term solution is for the view to become a materialized
 view (PostgreSQL 9.3+). A temporary solution is to rename the view to
 something different and then create a table based upon the view.
 ALTER VIEW geometry_columns RENAME TO _geometry_columns;
 CREATE TABLE geometry_columns AS
   SELECT * FROM _geometry_columns;
 You'd have to update the table once in a while though...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2365#comment:2>
