[postgis-tickets] [PostGIS] #2366: Cancelling query with ST_Union crashes PostgreSQL server
PostGIS trac at osgeo.org
Thu Jun 20 07:52:05 PDT 2013
 Reporter:  dbaston  |       Owner:  robe
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 If you still have issue after upgrading to 2.0.3, you may want to check
 your shared memory setting.  PostgreSQL particular on windows gets pretty
 unstable if that is set too high.  Even for 64-bit I haven't tried going
 beyond 2GB (so not sure the upper on that) or but would depend on amount
 of memory you have on your box available.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2366#comment:3>
