[postgis-tickets] [PostGIS] #2213: postgis-2.1.so: undefined symbol: json_tokener_errors
PostGIS trac at osgeo.org
Thu Jun 20 08:23:18 PDT 2013
 Reporter:  mloskot  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:  json-c   |
Comment(by strk):
 Yep, you could look first in the old, if it fails look in the new, and in
 both cases link to the old. I'm guessing here that putting the new library
 into the 5th arg of AC_CHECK_LIB (other-libraries -- http://www.gnu.org
 /savannah-
 checkouts/gnu/autoconf/manual/autoconf-2.69/html_node/Libraries.html)
 would error out when configuring against old libjson.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2213#comment:13>
