[postgis-tickets] [PostGIS] #2213: postgis-2.1.so: undefined symbol: json_tokener_errors
PostGIS trac at osgeo.org
Thu Jun 20 13:49:20 PDT 2013
 Reporter:  mloskot  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:  json-c   |
Comment(by kashif):
 Yes so that's what I tried initially, a one line change:
 -AC_CHECK_LIB([json], [json_object_get], [HAVE_JSON=yes], [], [])
 +AC_SEARCH_LIBS([json_object_get], [json-c json], [HAVE_JSON=yes], [], [])
 And it finds the newer json-c, but when compiling I get a linker error:
 $ make
 st_2d.o gserialized_gist_nd.o gserialized_estimate.o geography_inout.o
 geography_btree.o geography_measurement.o
 geography_measurement_trees.o geometry_inout.o
 -L/usr/local/Cellar/postgresql/9.2.4/lib -L/usr/local/Cellar/ossp-
 uuid/1.6.2/lib  -Wl,-dead_strip_dylibs   ../libpgcommon/libpgcommon.a
 ../liblwgeom/.libs/liblwgeom.a
 -L/usr/local/Cellar/geos/3.3.8/lib  -lgeos_c -lproj -ljson -lxml2
 -bundle_loader
 /usr/local/Cellar/postgresql/9.2.4/bin/postgres
 Undefined symbols for architecture x86_64:
   "_json_object_array_get_idx", referenced from:
       _parse_geojson in liblwgeom.a(lwin_geojson.o)
       _parse_geojson_coord in liblwgeom.a(lwin_geojson.o)
   "_json_object_array_length", referenced from:
 ld: symbol(s) not found for architecture x86_64
 clang: error: linker command failed with exit code 1 (use -v to see
 invocation)
 make[1]: *** [postgis-2.2.so] Error 1
 make: *** [all] Error 1
 and it seems that the -Wl,-dead_strip_dylibs  flag is striping out the
 libjson-c which is linked into the the older libjson shared lib:
 $ otool -L libjson.0.dylib
 libjson.0.dylib:
     /usr/local/lib/libjson.0.dylib (compatibility version 2.0.0, current
 version 2.0.0)
     /usr/local/lib/libjson-c.2.dylib (compatibility version 3.0.0, current
 version 3.0.0)
     /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current
 version 169.3.0)
 I have an issue about it on github:
 https://github.com/json-c/json-c/issues/79
 Hope this helps.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2213#comment:19>
