[postgis-tickets] [PostGIS] #2330: SFCGAL install does not specify minimum boost required
PostGIS trac at osgeo.org
Sat Jun 22 17:53:10 PDT 2013
 Reporter:  robe    |       Owner:  colivier
     Type:  defect  |      Status:  new
 Priority:  low     |   Milestone:  PostGIS 2.2.0
Component:  sfcgal  |     Version:  trunk
 Keywords:          |
Changes (by robe):
  * priority:  blocker => low
  * milestone:  PostGIS 2.1.0 => PostGIS 2.2.0
Comment:
 We still should state the minimums in the docs but since you did change so
 it works with 1.46 I think this is now low priority
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2330#comment:5>
