[postgis-tickets] [PostGIS] #2364: Setup winnie with a mingw64 gcc 4.8.0 seh chain
PostGIS trac at osgeo.org
Sun Jun 23 21:44:09 PDT 2013
 Reporter:  robe           |       Owner:  robe
     Type:  task           |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  buildbots      |     Version:  2.1.x
 Keywords:  windows64,edb  |
Comment(by robe):
 Done -- she is now building 9.3x64bit PostGIS 2.1 and 2.2 with gcc 4.8
 seh.  I still need to recompile boost, cgal to support pgrouting (in 2.1)
 since the current 9.3 pgrouting I have compiled is incompatible with the
 4.8 seh.  This I hope to reuse for building sfcgal (in 2.2) so I'll
 probably go with a newer chain of CGAL than I did with other pgrouting.
 I was also insane enough to use a newer msys chain --
 http://sourceforge.net/projects/mingwbuilds/files/external-binary-packages
 (msys+7za+wget+svn+git+mercurial+cvs-rev13.7z)  which I chose because it
 came all packaged with svn and git yippee.
 Unfortunately that meant I needed to be really careful with my PATH
 setting to insure the msys libraries were found last since it caused some
 CreateProcess errors (when I mistakenly had those first in my path). I
 also decided to use fstabs heavily this time so my carry along ming chain
 doesn't have to sit on the C drive and projects folder can be moved
 anywhere.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2364#comment:4>
