[postgis-tickets] [PostGIS] #2363: st_distance with an added Integer value is not working in 2.0
PostGIS trac at osgeo.org
Mon Jun 24 08:03:48 PDT 2013
 Reporter:  vbalent  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by vbalent):
 I forgot to ask -- did you verify you get the same answer on both servers
 for this query -- I just tried my 1.5 and 2.0 installs on separate servers
 and got the same answer.
 Yes I did check and received the exact same numbers in both environments.
 I wish you could help find this proj environment variable in Linux.
 On a side note when I do bump my radius from 1 mile (5280 Feet),  No
 records,
 However when I bump the Radius search to like 300 miles out I DO get
 records returned.
 Any thuoghts?
 Val
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2363#comment:6>
