[postgis-tickets] [PostGIS] #2363: st_distance with an added Integer value is not working in 2.0
PostGIS trac at osgeo.org
Mon Jun 24 12:49:08 PDT 2013
 Reporter:  vbalent  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 Hmm don't see a PROJ_LIB set, and I think if not set it uses the default
 location which might vary depending on OS.
 Details described here: http://home.gdal.org/projects/wcts/install.html
 BUT: YOU STILL DID NOT ANSWER MY QUESTION:  What does this query return?
 SELECT ST_AsText(
    ST_Transform(
      ST_POINTFROMTEXT('POINT(-73.76545859999999 42.658618)', 4326), 2260)
 Mine returns:
 -- answer  POINT(689696.298242221 1394398.10155405)
 If you get the same or similar answer then proj is not your issue and you
 probably have a more obvious problem of your datasets are simply different
 on the two systems.
 If you get a different answer, then proj is your issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2363#comment:8>
