[postgis-tickets] [PostGIS] #2369: SQL Statemant Works in Windows version 1.5x Not in Liunx version 2.0x
PostGIS trac at osgeo.org
Tue Jun 25 11:41:04 PDT 2013
 Reporter:  vbalent  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Changes (by dustymugs):
  * priority:  critical => high
  * milestone:  PostGIS 2.1.0 => PostGIS 2.0.4
Comment:
 What's the projection of P1.GEOM and PZ.the_geom? And are you sure that
 the geometries are in the projection indicated by the SRID? Your last
 ticket showed that the geometries were not in the projection of the
 recorded SRID.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2369#comment:1>
