[postgis-tickets] [PostGIS] #2370: ST_EstimatedExtent bug
PostGIS trac at osgeo.org
Wed Jun 26 14:52:52 PDT 2013
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
Comment(by strk):
 I don't think it's important for "estimated" bounding box to be larger
 than the actual one.
 It's important that it is "about the same as the actual one", based on a
 sample.
 If the sample is the whole set, I'd expect the estimated extent to also be
 the one of the whole set. That's how it worked up to 2.0. Do you have a
 case for that 1% enlargement ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2370#comment:7>
