[postgis-tickets] [PostGIS] #2372: KML with space around ordinate values considered invalid
PostGIS trac at osgeo.org
Fri Jun 28 11:53:31 PDT 2013
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 1.5.9
 Component:  postgis  |     Version:  1.5.X
Resolution:  fixed    |    Keywords:  history, kml
Comment(by colivier):
 The KML spec is provided by OGC
 http://www.opengeospatial.org/standards/kml
 The paragraph related to coordinatesType seems to me quite clear:
 "String representing one or more coordinate tuples, with each tuple
 consisting of decimal values for geodetic longitude, geodetic latitude,
 and altitude. The altitude component is optional. The coordinate separator
 is a comma and the tuple separator is a whitespace. Longitude and latitude
 coordinates are expressed in decimal degrees only."
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2372#comment:11>
