[postgis-tickets] [PostGIS] #2372: KML with space around ordinate values considered invalid
PostGIS trac at osgeo.org
Sat Jun 29 02:08:30 PDT 2013
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  high     |   Milestone:  PostGIS 1.5.9
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  history, kml
Comment(by colivier):
 No the spec is NOT respected anymore.
 As if you use the same char (space here) for tuple separator AND for
 coordinate separator
 you have no control on what you are parsing (meaning tuples and
 dimensions)
 Few samples:
  SELECT 'Valid KML', ST_AsEWKT(ST_GeomFromKML('
                 <LineString>
                         <coordinates>-71.1663,42.2614
 -71.1667,42.2616</coordinates>
                 </LineString>'));
 SELECT 'Junk KML I', ST_AsEWKT(ST_GeomFromKML('
                 <LineString>
                         <coordinates>-71.1663,42.2614, 12 -71.1667,
 42.2616,14</coordinates>
                 </LineString>'));
 SELECT 'Junk KML II', ST_AsEWKT(ST_GeomFromKML('
                 <LineString>
                         <coordinates>-71.1663,42.2614, 12 42.2616,
 14</coordinates>
                 </LineString>'));
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2372#comment:14>
