[postgis-tickets] [PostGIS] #2372: KML with space around ordinate values considered invalid
PostGIS trac at osgeo.org
Sun Jun 30 12:41:55 PDT 2013
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  high     |   Milestone:  PostGIS 1.5.9
 Component:  postgis  |     Version:  1.5.X
Resolution:           |    Keywords:  history, kml
Comment(by colivier):
 But how could 'Junk KML I'  be a valid KML 2.2 3D Linestring ?
 It just broke the spec.
 I could hear that from your point of view you it's a progress to allow
 some invalid data to also be parsed.
 But from my point of view it's a regress, because we loose the validation
 information.
 Adding a ST_MakeValidKML seems clearly overkill,
 but an extra parameter to ST_GeomFromKML allowing the end user to switch
 from one behaviour to an another could make sense
 at the very minimum printing a NOTICE each time we met an invalid data.
 For Junk KML II, it's was just a sample,
 there's possibly some other use case quite similar
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2372#comment:16>
