[postgis-tickets] [PostGIS] #2218: json broken on windows
PostGIS trac at osgeo.org
Fri Mar 1 00:13:12 PST 2013
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Oops, I was wrong, "boolean" is defined within the same header!
 line 32: typedef int boolean;
 So maybe it's the other way around: something is defining "boolean"
 _before_ including that header ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2218#comment:3>
