[postgis-tickets] [PostGIS] #2202: No option to disable json-c lookup by ./configure
PostGIS trac at osgeo.org
Mon Mar 4 10:11:20 PST 2013
 Reporter:  mloskot                |       Owner:  mloskot
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.1.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:  jsonc                  |
Changes (by strk):
  * milestone:  PostGIS 2.0.3 => PostGIS 2.1.0
Comment:
 change in configure name goes to 2.1.0.
 If you come up with a working patch I'll apply.
 By working I mean that no switch enables it if available, --without
 disables it without complaining and --with complains if not found or uses
 from given path if found
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2202#comment:3>
