[postgis-tickets] [PostGIS] #1553: TGEOM serialization documentation file
PostGIS trac at osgeo.org
Mon Mar 4 10:18:39 PST 2013
 Reporter:  colivier             |       Owner:  colivier
     Type:  task                 |      Status:  new
 Priority:  blocker              |   Milestone:  PostGIS 2.0.4
Component:  postgis              |     Version:  2.0.x
 Keywords:  TGEOM serialization  |
Changes (by strk):
  * milestone:  PostGIS 2.0.3 => PostGIS 2.0.4
Comment:
 Olivier: did you ever try to valgrind the cu_tester run ?
 cd liblwgeom/cunit;
 libtool --mode=execute valgrind --leak-check=full ./cu_tester surface
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1553#comment:7>
