[postgis-tickets] [PostGIS] #2223: Rules on geometry_columns make noisy backup/restore
PostGIS trac at osgeo.org
Mon Mar 4 21:02:45 PST 2013
 Reporter:  pramsey                |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.4
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:  rules                  |
 On an ordinary database, using CREATE EXTENSION to enable PostGIS, and
 dumping using pg_dump as follows
 pg_dump --file=nyc.backup --format=c --port=54321 --username=postgres nyc
 createdb -p 54321 nyc2
 pg_restore --dbname=nyc2 --port 54321 --username=postgres nyc.backup
 The restore generates the following errors
 pg_restore: [archiver (db)] Error while PROCESSING TOC:
 pg_restore: [archiver (db)] Error from TOC entry 3249; 2618 19424 RULE
 geometry_columns_delete postgres
 pg_restore: [archiver (db)] could not execute query: ERROR:  rule
 "geometry_columns_delete" for relation "geometry_columns" already exists
     Command was: CREATE RULE geometry_columns_delete AS ON DELETE TO
 geometry_columns DO INSTEAD NOTHING;
 pg_restore: [archiver (db)] Error from TOC entry 3247; 2618 19422 RULE
 geometry_columns_insert postgres
 "geometry_columns_insert" for relation "geometry_columns" already exists
     Command was: CREATE RULE geometry_columns_insert AS ON INSERT TO
 pg_restore: [archiver (db)] Error from TOC entry 3248; 2618 19423 RULE
 geometry_columns_update postgres
 "geometry_columns_update" for relation "geometry_columns" already exists
     Command was: CREATE RULE geometry_columns_update AS ON UPDATE TO
 This is unfortunate, since our dump/restore story is now supposed to be
 pristine in the new world of extensions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2223>
