[postgis-tickets] [PostGIS] #2224: [raster]: raster2pgsql tiled outdb with overviews crashes
PostGIS trac at osgeo.org
Tue Mar 5 08:01:20 PST 2013
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  high    |   Milestone:  PostGIS 2.1.0
Component:  raster  |     Version:  trunk
 Keywords:          |
Comment(by robe):
 Driver: JPEG/JPEG JFIF
 Files: 25229020.sid.jpg
        25229020.sid.jpg.aux.xml
 Size is 5000, 5000
 Coordinate System is:
 PROJCS["NAD83 / Massachusetts Mainland",
     GEOGCS["NAD83",
         DATUM["North_American_Datum_1983",
             SPHEROID["GRS 1980",6378137,298.2572221010002,
                 AUTHORITY["EPSG","7019"]],
             AUTHORITY["EPSG","6269"]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433],
         AUTHORITY["EPSG","4269"]],
     PROJECTION["Lambert_Conformal_Conic_2SP"],
     PARAMETER["standard_parallel_1",42.68333333333333],
     PARAMETER["standard_parallel_2",41.71666666666667],
     PARAMETER["latitude_of_origin",41],
     PARAMETER["central_meridian",-71.5],
     PARAMETER["false_easting",200000],
     PARAMETER["false_northing",750000],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AUTHORITY["EPSG","26986"]]
 Origin = (251486.436173995750000,902771.024778253280000)
 Pixel Size = (0.300000000000017,-0.300000000000023)
 Metadata:
   GEOTIFF_CHAR__GTModelTypeGeoKey=ModelTypeProjected
   GEOTIFF_CHAR__GTRasterTypeGeoKey=RasterPixelIsArea
   GEOTIFF_CHAR__ProjectedCSTypeGeoKey=PCS_NAD83_Massachusetts
   GEOTIFF_CHAR__ProjLinearUnitsGeoKey=Linear_Meter
   GEOTIFF_NUM__1024__GTModelTypeGeoKey=1
   GEOTIFF_NUM__1025__GTRasterTypeGeoKey=1
   GEOTIFF_NUM__1026__GTCitationGeoKey=IMAGINE GeoTIFF Support
 Copyright 1991 - 2005 by Leica Geosystems Geospatial Imaging, LLC. All
 Rights R
 served
 @(#)$RCSfile: egtf.c $ IMAGINE 9.0 $Revision: 10.0 $ $Date: 2005/07/26
 15:10:00
 EST $
 Projection Name = State Plane
 Units = meters
 GeoTIFF Units = meters
   GEOTIFF_NUM__3072__ProjectedCSTypeGeoKey=26986
   GEOTIFF_NUM__3073__PCSCitationGeoKey=IMAGINE GeoTIFF Support
 Rights R
 served
 15:10:00
 EST $
 State Plane Zone -2001
 NAD = 83
   GEOTIFF_NUM__3076__ProjLinearUnitsGeoKey=9001
   IMAGE__BITS_PER_SAMPLE=8
   IMAGE__COLOR_SCHEME=0
   IMAGE__COMPRESSION_BLOCK_SIZE=512
   IMAGE__COMPRESSION_GAMMA=2.000000
   IMAGE__COMPRESSION_NLEV=7
   IMAGE__COMPRESSION_VERSION=2,0,0
   IMAGE__COMPRESSION_WEIGHT=2.000000
   IMAGE__CREATION_DATE=Tue Nov 18 10:44:29 2008
   IMAGE__DATA_TYPE=0
   IMAGE__DYNAMIC_RANGE_LEVEL=127.500000
   IMAGE__DYNAMIC_RANGE_WINDOW=256.000000
   IMAGE__ENCODING_APPLICATION=GeoExpress 6.0.0.1331
   IMAGE__HEIGHT=5000
   IMAGE__INPUT_FILE_SIZE=76841077.000000
   IMAGE__INPUT_FORMAT=GeoTIFF
   IMAGE__INPUT_NAME=M:\sp_tiffs\25229020.tif
   IMAGE__TARGET_COMPRESSION_RATIO=14.999999
   IMAGE__WIDTH=5000
   IMAGE__WKT=PROJCS["NAD83 / Massachusetts
 Mainland",GEOGCS["NAD83",DATUM["Nort
 _American_Datum_1983",SPHEROID["GRS
 1980",6378137,298.2572221010002,AUTHORITY["
 PSG","7019"]],AUTHORITY["EPSG","6269"]],PRIMEM["Greenwich",0],UNIT["degree",0.0
 74532925199433],AUTHORITY["EPSG","4269"]],PROJECTION["Lambert_Conformal_Conic_2
 P"],PARAMETER["standard_parallel_1",42.68333333333333],PARAMETER["standard_para
 lel_2",41.71666666666667],PARAMETER["latitude_of_origin",41],PARAMETER["central
 meridian",-71.5],PARAMETER["false_easting",200000],PARAMETER["false_northing",7
 0000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPSG","26986"]]
   IMAGE__X_RESOLUTION=0.300000
   IMAGE__XY_ORIGIN=251486.586174,902770.874778
   IMAGE__Y_RESOLUTION=0.300000
   VERSION=MG2
 Image Structure Metadata:
   COMPRESSION=JPEG
   INTERLEAVE=PIXEL
   SOURCE_COLOR_SPACE=YCbCr
 Corner Coordinates:
 Upper Left  (  251486.436,  902771.025) ( 70d52'29.52"W, 42d22'25.48"N)
 Lower Left  (  251486.436,  901271.025) ( 70d52'30.01"W, 42d21'36.87"N)
 Upper Right (  252986.436,  902771.025) ( 70d51'23.96"W, 42d22'25.12"N)
 Lower Right (  252986.436,  901271.025) ( 70d51'24.46"W, 42d21'36.51"N)
 Center      (  252236.436,  902021.025) ( 70d51'56.99"W, 42d22' 1.00"N)
 Band 1 Block=5000x1 Type=Byte, ColorInterp=Red
     COMPRESSION=JPEG
 Band 2 Block=5000x1 Type=Byte, ColorInterp=Green
     COMPRESSION=JPEG
 Band 3 Block=5000x1 Type=Byte, ColorInterp=Blue
     COMPRESSION=JPEG
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2224#comment:5>
