[postgis-tickets] [PostGIS] #2226: [raster]: Regress failure on window 8.4 32-bit
PostGIS trac at osgeo.org
Sun Mar 10 15:17:33 PDT 2013
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  high    |   Milestone:  PostGIS 2.0.4
Component:  raster  |     Version:  2.0.x
 Keywords:          |
 I was really hoping I'd never have to look at 8.4 again.  Oh well.
 In packaging 8.4 PostGIS 2.0 for windows, running into a regress issue:
  PostgreSQL 8.4.8, compiled by Visual C++ build 1400, 32-bit
  Postgis 2.0.3 - r11128 - 2013-03-10 21:50:06
    GEOS: 3.3.8-CAPI-1.7.8
    PROJ: Rel. 4.8.0, 6 March 2012
    GDAL: GDAL 1.9.1, released 2012/05/15
 Running tests
  check_gdal .. ok
  check_raster_columns .. ok
  check_raster_overviews .. ok
  rt_io .. ok
  rt_bytea .. ok
  box3d .. ok
  rt_addband .. ok
  rt_band .. ok
  rt_asgdalraster .. ok
  rt_astiff .. ok
  rt_asjpeg .. ok
  rt_aspng .. ok
  rt_union .. ok
  create_rt_properties_test .. ok
  rt_dimensions .. ok
  rt_scale .. ok
  rt_pixelsize .. ok
  rt_upperleft .. ok
  rt_rotation .. ok
  rt_georeference .. ok
  rt_set_properties .. ok
  drop_rt_properties_test .. ok
  create_rt_empty_raster_test .. ok
  rt_isempty .. ok
  rt_hasnoband .. ok
  drop_rt_empty_raster_test .. ok
  rt_metadata .. ok
  create_rt_band_properties_test .. ok
  rt_band_properties .. ok
  rt_set_band_properties .. ok
  rt_summarystats .. ok
  rt_count .. ok
  rt_histogram .. ok
  rt_quantile .. ok
  rt_valuecount .. ok
  rt_valuepercent .. ok
  rt_bandmetadata .. ok
  rt_pixelvalue .. ok
  drop_rt_band_properties_test .. ok
  rt_utility .. ok
  create_rt_mapalgebra_test .. ok
  rt_mapalgebraexpr .. ok
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  drop_rt_mapalgebra_test .. ok
  create_rt_mapalgebrafctngb_test .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  drop_rt_mapalgebrafctngb_test .. ok
  rt_reclass .. ok
  rt_resample .. failed (diff expected obtained:
 /tmp/pgis_reg/test_52_diff)
  rt_asraster .. failed (diff expected obtained:
 /tmp/pgis_reg/test_53_diff)
  rt_intersection .. ok
  rt_clip .. ok
  create_rt_gist_test .. ok
  rt_above .. ok
  rt_below .. ok
  rt_contained .. ok
  rt_contain .. ok
  rt_left .. ok
  rt_overabove .. ok
  rt_overbelow .. ok
  rt_overlap .. ok
  rt_overleft .. ok
  rt_overright .. ok
  rt_right .. ok
  rt_same .. ok
  drop_rt_gist_test .. ok
  rt_spatial_relationship .. ok
  rt_intersects .. ok
  rt_samealignment .. ok
  bug_test_car5 .. ok
  tickets .. ok
  loader/Basic ...... ok
  loader/BasicCopy ...... ok
  loader/Tiled10x10 ..... ok
  loader/Tiled10x10Copy ..... ok
  uninstall ... ok (3699)
 It's possible this affects all 8.4's since neigther winnie nor debbie test
 against PostgreSQL 8.4.
 Regress failures attached.
 I'm going to upgrade the gdal version to 1.9.2 to see if that fixes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2226>
