[postgis-tickets] [PostGIS] #2232: Accumulated error with relative coordinates in ST_AsSvg
PostGIS trac at osgeo.org
Thu Mar 14 15:17:09 PDT 2013
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 When using ST_ASSvg outputting relative rounded coordinates you might get
 accumulated rounding errors.
 I saw huge errors like that when testing twkb on polygons with thousands
 of vertex-points.
 Example:
 select
 st_assvg('LINESTRING(0 0, 0.4 0, 0.8 0, 1.2 0,1.6 0, 2 0)'::geometry,1,0)
 returns:
 M 0 0 l 0 0 0 0 0 0 0 0 0 0
 I fixed it in twkb-case in the spike with #11165, probably the same
 approach can be used here.
 Just not get the relative value as relative to the previous coordinate,
 but relative to the accumulates relative coordinates achieved.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2232>
