[postgis-tickets] [PostGIS] #2232: Accumulated error with relative coordinates in ST_AsSvg
PostGIS trac at osgeo.org
Fri Mar 15 06:38:11 PDT 2013
 Reporter:  nicklas  |       Owner:  nicklas
     Type:  defect   |      Status:  assigned
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Description changed by nicklas:
Old description:
> When using ST_ASSvg outputting relative rounded coordinates you might get
> accumulated rounding errors.
> I saw huge errors like that when testing twkb on polygons with thousands
> of vertex-points.
> Example:
> select
> st_assvg('LINESTRING(0 0, 0.4 0, 0.8 0, 1.2 0,1.6 0, 2 0)'::geometry,1,0)
> returns:
> M 0 0 l 0 0 0 0 0 0 0 0 0 0
> I fixed it in twkb-case in the spike with #11165, probably the same
> approach can be used here.
> Just not get the relative value as relative to the previous coordinate,
> but relative to the accumulates relative coordinates achieved.
New description:
 of vertex-points.
 Example:
 select
 returns:
 I fixed it in twkb-case in the spike with r11165, probably the same
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2232#comment:2>
