[postgis-tickets] [PostGIS] #2235: PostGIS 2.0 on RHEL 5.9
PostGIS trac at osgeo.org
Fri Mar 15 14:10:48 PDT 2013
  Reporter:  rhood    |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:
 Component:  postgis  |     Version:  2.0.x
Resolution:  invalid  |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 rhood,
 I presume you are using the yum.postgresql.org packaging. That has to be
 reported there not here or just discussed on postgis-users mailing list.
 Unfortunately I think for lower versions of Redhat, devrim had issues
 getting rasters included because of other dependencies and the extension
 isn't included unless postgis was compiled with raster support.
 You can install the old fashioned way if you don't need raster support.
 The .sql files will be in the usual share/contrib/postgis... folder.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2235#comment:1>
