[postgis-tickets] [PostGIS] #2233: [raster]: change error could not run alignment test to a warning
PostGIS trac at osgeo.org
Sun Mar 17 19:35:11 PDT 2013
  Reporter:  robe         |       Owner:  dustymugs
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  PostGIS 2.1.0
 Component:  raster       |     Version:  trunk
Resolution:  invalid      |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
  * milestone:  PostGIS 2.0.4 => PostGIS 2.1.0
Comment:
 I'll mark this as invalid.  Might have been because I had on the server he
 was loading a very old version of 2.1.0SVN and I upgraded it to test the
 ST_Resize issue and now I all I see is an:
 INFO: Using default geotransform matrix (0, 1, 0, 0, 0, -1) for raster
 when loading the same file he was loading.  I'll reopen if it has
 something to do with the flags he was using.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2233#comment:3>
