[postgis-tickets] [PostGIS] #2228: topology.AsTopoJSON(TopoGeometry)
PostGIS trac at osgeo.org
Mon Mar 18 10:23:47 PDT 2013
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Example outputs:
 {"type": "LineString", "arcs": [42, 43]}
 {"type": "Polygon", "arcs": [[42, 43], [44]]}
 The numbers in square brackets (array elements) are "arc identifiers",
 pretty much like our edge identifiers except they are (0-based) indices
 into an array, which we'll need to build somehow.
 Also, backward arcs/edges are expressed with -(INDEX+1)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2228#comment:1>
