[postgis-tickets] [PostGIS] #2239: regress failure on postgresql 9.0 on windows
PostGIS trac at osgeo.org
Wed Mar 20 20:26:30 PDT 2013
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:  windows  |
Changes (by robe):
  * priority:  critical => blocker
Comment:
 Well anyway clearing that folder doesn't help.  I'll test locally in a
 bit, but it seems somehow your change screwed up (at least on mingw64)
 ability for it to differentiate between PostgreSQL 9.0 and above, because
 the install failure is happening because ORDER BY support is only valid
 for PostgreSQL 9.1+ since it relies on KNN logic introduced in 9.1 but its
 being left in for 9.0.
   OPERATOR        13       <-> FOR ORDER BY pg_catalog.float_...
 Personally.  I DON'T like this change you made on postgis.sql.in.c and
 other files that require c preprocessing.
 Those files have C defines in it and to me they should have a .c extension
 to distinguish them from other .sql.in files that say go thru your perl
 preprocessor.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2239#comment:5>
