[postgis-tickets] [PostGIS] #2239: regress failure on postgresql 9.0 on windows
PostGIS trac at osgeo.org
Thu Mar 21 01:08:54 PDT 2013
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:  windows  |
Comment(by strk):
 Another thing, cpp(1) manual talks about a -x switch that can be used to
 specify the language, can you check if adding -x c fixes the issue for you
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2239#comment:9>
