[postgis-tickets] [PostGIS] #2244: [raster]: ST_SetGeoReference screws up out db
PostGIS trac at osgeo.org
Sun Mar 24 10:16:55 PDT 2013
 Reporter:  robe      |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.1.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 Not sure what causes this issue whether a doc bug or something not right
 in out db support. I thought we had this probelm before and it was fixed,
 but I just updated to the latest.
 PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
 POSTGIS="2.1.0SVN r11197" GEOS="3.4.0dev-CAPI-1.8.0 r0" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER
 I imported this image twice -- one as in db and one as outdb
 http://download.osgeo.org/postgis/logo_suite/adbadge_tall/adbadge_tall.png
 SET PGPORT=5442
 SET PGHOST=localhost
 SET PGUSER=postgres
 SET PGDATABASE=testpostgis21
 raster2pgsql C:/pics/adbadge_tall.png test_pele | psql
 raster2pgsql -e -R -a C:/pics/adbadge_tall.png test_pele | psql
 -- After georeferencing
 SELECT rid, (h).*
 FROM (SELECT rid, ST_Histogram(ST_SetGeoReference(rast, '1 0 0 -1 445139
 5415000'),1,4) As h
 from test_pele) As a;
  rid | min | max | count  |      percent
    1 |  15 |  75 |  13456 |  0.025542900531511
    1 |  75 | 135 |  23572 | 0.0447456340167046
    1 | 135 | 195 |  50711 | 0.0962623386484434
    1 | 195 | 255 | 439061 |  0.833449126803341
    2 |   0 |   0 | 526800 |                 -1
 (5 rows)
 But before that they return same answer
 --before georeferencing --
 SELECT rid, (h).*
 FROM (SELECT rid, ST_Histogram(rast,1,4) As h
    2 |  15 |  75 |  13456 |  0.025542900531511
    2 |  75 | 135 |  23572 | 0.0447456340167046
    2 | 135 | 195 |  50711 | 0.0962623386484434
    2 | 195 | 255 | 439061 |  0.833449126803341
 (8 rows)
 haven't tested on 2.0 to see if similar issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2244>
