[postgis-tickets] [PostGIS] #2244: [raster]: ST_SetGeoReference screws up out db
PostGIS trac at osgeo.org
Sun Mar 24 12:04:02 PDT 2013
 Reporter:  robe      |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.1.0
Component:  raster    |     Version:  trunk
 Keywords:            |
Comment(by dustymugs):
 That is expected behavior.  There is an expectation that the metadata
 stored in database and the actual raster file's metadata match
 (specifically the geotransform matrix).  If the metadata doesn't match,
 the output from a function (such as ST_Histogram) is unknown.  Non-
 georeferenced rasters are always set the default geotransform (scaleX: 1
 scaleY: -1 skewX/Y: 0 upperleftX/Y: 0 srid: 0).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2244#comment:2>
