[postgis-tickets] [PostGIS] #2251: [raster ] Rescaling raster chooses wrong values
PostGIS trac at osgeo.org
Tue Mar 26 11:30:24 PDT 2013
 Reporter:  dzwarg    |       Owner:  dustymugs
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:
Component:  postgis   |     Version:  2.0.x
 Keywords:  raster    |
 Using a test raster with 1 band, 8BUI, rescale uses the wrong scale factor
 to rescale the raster.
 The raster with id=1 was created with {{{
 select
 ST_AddBand(ST_MakeEmptyRaster(10,10,0,0,1,-1,0,0,0), '8BUI'::text, 1);
 Running rescale works on rasters that are not positioned on the origin,
 but the (0,0) upperleftx, upperlefty raster is scaled by the wrong factor.
 raster=# select id,st_metadata(rast), st_metadata(st_rescale(rast, 2, -2,
 'NearestNeighbor'::text)) from test order by id;
  id |         st_metadata         |        st_metadata
   1 | (0,0,10,10,1,-1,0,0,0,1)    | (0,0,50,50,1,-1,0,0,0,1)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2251>
