[postgis-tickets] [PostGIS] #2222: [raster] WKB format version 1
PostGIS trac at osgeo.org
Fri Mar 29 09:55:55 PDT 2013
 Reporter:  dustymugs    |       Owner:  dustymugs
     Type:  enhancement  |      Status:  assigned
 Priority:  medium       |   Milestone:  PostGIS 2.1.0
Component:  raster       |     Version:  trunk
 Keywords:               |
Changes (by dustymugs):
  * status:  new => assigned
Comment:
 After some additional thinking and discussion, the current thought is NOT
 to create a new version and cause lots of waves (and probably a whole slew
 of bugs) but to continue using the current WKB format as is.  Instead, we
 will allow end users to specify that they want out-db bands to be treated
 as in-db.  By default, the current behavior where out-db bands return the
 path to the external file will continue.  But if the user says to tread
 out-db as in-db, the behavior will change so that the appropriate data
 contained in the external file will be returned.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2222#comment:2>
