[postgis-tickets] [PostGIS] #1052: Tiger Geocoder 2010 Geocode() "squishing" toward end of block
PostGIS trac at osgeo.org
Fri Mar 29 20:02:07 PDT 2013
  Reporter:  mikepease       |       Owner:  robe
      Type:  enhancement     |      Status:  reopened
  Priority:  medium          |   Milestone:  PostGIS Future
 Component:  tiger geocoder  |     Version:  trunk
Resolution:                  |    Keywords:
Comment(by woodbri):
 I think that this could be closed as will not fix or not a bug. This is a
 Census data problem/limitation not a geocoder problem.
 If someone want to open an enhancement request to support parcel data,
 then I think that would be appropriate and maybe we could look at applying
 the PAGC address standardizer to that task after it is integrated into
 tiger geocoder.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1052#comment:33>
