[postgis-tickets] [PostGIS] #2330: SFCGAL install does not specify minimum boost required
PostGIS trac at osgeo.org
Wed May 15 01:26:10 PDT 2013
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  sfcgal   |     Version:  trunk
 Keywords:           |
 Olivier,
 I'm running into some issues with getting to compile sfcgal.  I have boost
 1.46 and CGAL 4.2 compiled.  I had to recompile boost because I had
 compiled a minimalist version and sfcgal seems to require a LOT of boost
 parts and after recompiling I was left with these last 2 dependencies.
 Now I am left with this:
 -- The C compiler identification is GNU 4.5.4
 -- The CXX compiler identification is GNU 4.5.4
 -- Check for working C compiler: c:/ming64/mingw64/bin/gcc.exe
 -- Check for working C compiler: c:/ming64/mingw64/bin/gcc.exe -- works
 -- Detecting C compiler ABI info
 -- Detecting C compiler ABI info - done
 -- Check for working CXX compiler: c:/ming64/mingw64/bin/g++.exe
 -- Check for working CXX compiler: c:/ming64/mingw64/bin/g++.exe -- works
 -- Detecting CXX compiler ABI info
 -- Detecting CXX compiler ABI info - done
 -- Boost_USE_STATIC_LIBS=OFF
 -- Boost_USE_MULTITHREAD=ON
 CMake Error at C:/ming64/msys/share/cmake-2.8/Modules/FindBoost.cmake:1192
 (mess
 age):
   Unable to find the requested Boost libraries.
   Boost version: 1.46.1
   Boost include path:
   c:/ming64/projects/boost/rel-1.46w64/include/boost-1_46_1
   The following Boost libraries could not be found:
           boost_chrono
           boost_timer
   Some (but not all) of the required Boost libraries were found.  You may
   need to install these additional Boost libraries.  Alternatively, set
   BOOST_LIBRARYDIR to the directory containing Boost libraries or
 BOOST_ROOT
   to the location of Boost.
 Call Stack (most recent call first):
   CMakeLists.txt:46 (find_package)
 -- Found GMP: c:/ming64/mingw64/include
 -- GMP_INCLUDE_DIRS = c:/ming64/mingw64/include
 -- GMP_LIBRARIES = c:/ming64/projects/CGAL/rel-gmp-5.1.1w64/lib/libgmp.a
 -- Found MPFR: c:/ming64/mingw64/include
 -- MPFR_INCLUDE_DIRS = c:/ming64/mingw64/include
 -- MPFR_LIBRARIES = c:/ming64/projects/CGAL/rel-
 mpfr-3.1.2w64/lib/libmpfr.a
 -- Found CGAL: c:/ming64/projects/CGAL/rel-cgal-4.2w64/include
 -- CGAL  found
 -- Could NOT find Doxygen (missing:  DOXYGEN_EXECUTABLE)
 -- Configuring incomplete, errors occurred!
 It seems boost_chrono came in boost 1.47.  according to this:
 http://stackoverflow.com/questions/6730422/boost-chrono-vs-boost-date-time
 Does SFCGAL really need like 20 bits of boost or can we reduce teh
 footprint a bit so mere mortals or people with not more up to date boost
 can compile this :)
 FROM CGAL 4.2 make -- all CGAL 4.2 uses from boost is boost_thread and
 boost_system
 Also do we really need DOXYGEN to be able to compile this?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2330>
