[postgis-tickets] [PostGIS] #2334: Cannot upgrade from 2.0 to 2.1
PostGIS trac at osgeo.org
Wed May 15 17:08:04 PDT 2013
 Reporter:  dustymugs  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  blocker    |   Milestone:  PostGIS 2.1.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
 Upgrading a test database from 2.0 to 2.1 using postgis_upgrade_20_21.sql,
 I get the following error message...
 psql:postgis_upgrade_20_21.sql:4323: ERROR:  cannot drop function
 geometry_gist_sel_2d(internal,oid,internal,integer) because other objects
 depend on it
 DETAIL:  operator &&(geometry,geometry) depends on function
 operator class gist_geometry_ops_2d for access method gist depends on
 HINT:  Use DROP ... CASCADE to drop the dependent objects too.
 If postgis/postgis_drop_before.sql is used before calling
 postgis_upgrade_20_21.sql, the error goes away.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2334>
