[postgis-tickets] [PostGIS] #2337: support parallel loading of state data
PostGIS trac at osgeo.org
Sat May 18 11:20:33 PDT 2013
 Reporter:  robe            |       Owner:  robe
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.2.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
 this is sort of a defect since its not stated it can't be done and yet
 separate scripts re created for each state.
 Right now I think the only thiing stopping from being able to do a
 parallel load of state data is that the generated script drops the
 tiger_staging schema after each load.
 If it were changed to only create the schema if not present and then only
 drop tables it creates in the process, it would be possible to run scripts
 in parallel to download and process each state without each script
 clubbering any other.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2337>
