[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
PostGIS trac at osgeo.org
Sun May 19 21:59:38 PDT 2013
 Reporter:  mwtoews     |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  blocker     |   Milestone:  PostGIS 2.0.4
Component:  postgis     |     Version:  2.0.x
 Keywords:  windows 64  |
Comment(by robe):
 dustymugs -- thanks.  FWIW I've isolated the problem areas down to:
 http://postgis.net/docs/doxygen/2.1/d9/d6e/lwgeom__inout_8c_source.html#l00066
 (line 66 of lwgeom_inout)
 SELECT ST_AsText('');  -- will trigger that part
 and I can prevent it from crashing if I replace:
    //ereport(ERROR,(errmsg("parse error - invalid geometry")));
    lwerror("parse error2 - invalid geometry");
    PG_RETURN_NULL();
 It also triggers at:
 http://postgis.net/docs/doxygen/2.1/d9/d6e/lwgeom__inout_8c_source.html#l00108
  if ( lwgeom_parse_wkt(&lwg_parser_result, str, LW_PARSER_CHECK_ALL) ==
 LW_FAILURE )
          PG_PARSER_ERROR(lwg_parser_result);
 For the inputs that mwtoews mentioned.  That I haven't bothered yet trying
 to fiddle with.
 Other observation -- if I set the functions to STABLE (instead of
 IMMUTABLE) that also seems to be as good as VOLATILE.  So maybe its
 because the STABLE memory event though its polluted may not matter since
 its thrown away anyway.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185#comment:32>
