[postgis-tickets] [PostGIS] #2542: isfinite needs _GNU_SOURCE defined on EL-5
PostGIS trac at osgeo.org
Mon Nov 11 13:06:07 PST 2013
 Reporter:  darkpanda  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.2
Component:  postgis    |     Version:  2.1.x
 Keywords:             |
 isfinite needs _GNU_SOURCE to be defined before including math.h on EL-5
 or you'll get linker errors when linking liblwgeom. Adding the following
 to the top of g_box.c will fix the problem:
 #ifndef _GNU_SOURCE
 #define _GNU_SOURCE
 #endif
 It seems the version of gcc on EL-5 is old enough that isfinite won't be
 included by default unless _GNU_SOURCE is defined, as the isfinite macro
 is a C99 feature.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2542>
