[postgis-tickets] [PostGIS] #2543: invalid join selectivity error from simple query
PostGIS trac at osgeo.org
Wed Nov 13 15:27:51 PST 2013
 Reporter:  paulfriedman  |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  high          |   Milestone:  PostGIS 2.1.2
Component:  postgis       |     Version:  2.1.x
 Keywords:                |
Comment(by pramsey):
 There's nothing wrong with a join selectivity of 1.0, so probably it's
 actually 1.000000001, but we're not seeing that in the print out. In that
 spirit, I've attached a patch, see if things work (they will). Maybe it
 should test for "within a tolerance" of 1.0 and error out if it exceeds
 that, rather than blindly flooring the value.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2543#comment:8>
