[postgis-tickets] [PostGIS] #2467: travis regress failure
PostGIS trac at osgeo.org
Mon Sep 2 20:39:50 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.2.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
Changes (by robe):
  * owner:  pramsey => robe
  * component:  postgis => buildbots
Comment:
 I changed travis bot to use verbose mode.  I also changed it to use the
 ubuntu ppa GEOS which seems to be GEOS 3.3.8 output is below.
 PostgreSQL 9.1.9 on x86_64-unknown-linux-gnu, compiled by gcc
 (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit
 Postgis 2.2.0dev - r11909 - 2013-09-03 03:22:38
 GEOS: 3.3.8-CAPI-1.7.8
 PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
 loader/Point .............. ok
 loader/PointM .............. ok
 loader/PointZ .............. ok
 loader/MultiPoint .............. ok
 loader/MultiPointM .............. ok
 loader/MultiPointZ .............. ok
 loader/Arc .............. ok
 loader/ArcM .............. ok
 loader/ArcZ .............. ok
 loader/Polygon .............. ok
 loader/PolygonM .............. ok
 loader/PolygonZ .............. ok
 loader/TSTPolygon ......... ok
 loader/TSIPolygon ......... ok
 loader/TSTIPolygon ......... ok
 loader/PointWithSchema ..... ok
 loader/NoTransPoint ......... ok
 loader/NotReallyMultiPoint ......... ok
 loader/MultiToSinglePoint ......... ok
 loader/ReprojectPts ........ ok
 loader/ReprojectPtsGeog ........ ok
 loader/Latin1 .... ok
 loader/Latin1-implicit .... ok
 binary .. ok
 regress .. ok
 regress_index .. ok
 regress_index_nulls .. failed (diff expected obtained:
 /tmp/pgis_reg/test_27_diff)
 --- regress_index_nulls_expected 2013-09-03 03:20:42.871536279 +0000
 +++ /tmp/pgis_reg/test_27_out 2013-09-03 03:23:48.262688931 +0000
 @@ -1,4 +0,0 @@
 -NOTICE: table "indexnulls" does not exist, skipping
 -NOTICE: table "indexempty" does not exist, skipping
 regress_selectivity .. ok
 lwgeom_regress .. ok
 regress_lrs .. ok
 removepoint .. ok
 setpoint .. ok
 simplify .. ok
 snaptogrid .. ok
 summary .. ok
 affine .. ok
 empty .. ok
 forcecurve .. ok
 measures .. ok
 legacy .. ok
 long_xact .. ok
 ctors .. ok
 sql-mm-serialize .. ok
 sql-mm-circularstring .. ok
 sql-mm-compoundcurve .. ok
 sql-mm-curvepoly .. ok
 sql-mm-general .. ok
 sql-mm-multicurve .. ok
 sql-mm-multisurface .. ok
 polyhedralsurface .. ok
 polygonize .. ok
 postgis_type_name .. ok
 geography .. ok
 out_geometry .. ok
 out_geography .. ok
 in_geohash .. ok
 in_gml .. ok
 in_kml .. ok
 iscollection .. ok
 regress_ogc .. failed (diff expected obtained: /tmp/pgis_reg/test_60_diff)
 --- regress_ogc_expected 2013-09-03 03:20:42.887529027 +0000
 +++ /tmp/pgis_reg/test_60_out 2013-09-03 03:23:49.630528472 +0000
 @@ -59,7 +59,6 @@
 within131|f
 overlaps|f
 isvalid|t
 -NOTICE: Self-intersection
 isvalid|f
 isvalid|t
 intersection|POINT(0 0)
 regress_ogc_cover .. ok
 regress_ogc_prep .. ok
 regress_bdpoly .. ok
 regress_proj .. ok
 regress_management .. ok
 dump .. ok
 dumppoints .. ok
 boundary .. ok
 wmsservers .. ok
 wkt .. ok
 wkb .. ok
 tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_72_diff)
 --- tickets_expected 2013-09-03 03:20:42.893500538 +0000
 +++ /tmp/pgis_reg/test_72_out 2013-09-03 03:23:50.387528286 +0000
 @@ -1,6 +1,5 @@
 #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
 #11|0
 -NOTICE: ST_Locate_Between_Measures and ST_Locate_Along_Measure are
 deprecated. Use ST_LocateAlong and ST_LocateBetween.
 #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
 t
 ERROR: AddGeometryColumn() - invalid SRID
 @@ -17,7 +16,6 @@
 #83|MULTICURVE(CIRCULARSTRING(220268 150415,220227 150505,220227 150406))
 #85|0
 #112|GEOMETRYCOLLECTION(POINT(-10 50))
 ERROR: Geometry argument does not have an 'M' ordinate
 #116|POLYGON EMPTY
 #122|CIRCULARSTRING(220268 150415,220227 150505,220227 150406)
 @@ -36,13 +34,10 @@
 #175|SRID=26915;POINT(482020 4984378)
 #178a|0
 #178b|5
 -NOTICE: No points or linestrings in input array
 #179a|
 #179b|
 #183|COMPOUNDCURVE(CIRCULARSTRING(0 0,0.5 1.2071067812,1 0),(1 0,0 1))
 #210a|
 #210b|
 #213|17
 #234|COMPOUNDCURVE((0 0,1 1))
 @@ -67,10 +62,8 @@
 #304.a|21
 #304.b|1
 #408|Too few points in geometry component[
 -NOTICE: Too few points in geometry component at or near point 0 0
 #408.1|f
 #408.2|Too few points in geometry component[0 0]
 -NOTICE: IllegalArgumentException: Invalid number of points in LinearRing
 found 2 - must be 0 or >= 4
 #408.3|f
 #408.4|IllegalArgumentException: Invalid number of points in LinearRing
 #457.1|POINT(0 0)
 @@ -145,14 +138,11 @@
 #1273.1|t
 ERROR: stats for "t.g" do not exist
 -WARNING: ST_Estimated_Extent signature was deprecated in 2.1.0. Please
 use ST_EstimatedExtent
 #877.4|-10.15000|20.15000|-50.40000|30.40000
 #877.5|-10.15000|20.15000|-50.40000|30.40000
 #1292|GEOMETRYCOLLECTION(POINT(180 90),POLYGON((140 50,150 50,180 50,140
 50),(140 60,150 60,180 60,140 60)))
 -NOTICE: Coordinate values were coerced into range [-180 -90, 180 90] for
 GEOGRAPHY
 GEOGRAPHY
 #1292.1|POINT(180 85)|POINT(-175 90)
 <#1320>
 #1320.geog.1|MULTIPOLYGON|4326
 @@ -210,7 +200,6 @@
 #1596.3|3395
 ERROR: invalid SRID: 999000 not found in spatial_ref_sys
 #1596.5|3395
 -NOTICE: SRID value -1 converted to the officially unknown SRID value 0
 #1596.6|public.road_pg.roads_geom SRID changed to 0
 #1596.7|0
 #1596|Point[BGS]
 typmod .. ok
 remove_repeated_points .. ok
 split .. ok
 relate .. ok
 bestsrid .. ok
 concave_hull .. ok
 hausdorff .. ok
 regress_buffer_params .. ok
 offsetcurve .. ok
 relatematch .. ok
 isvaliddetail .. ok
 sharedpaths .. ok
 snap .. ok
 node .. ok
 unaryunion .. ok
 clean .. ok
 relate_bnr .. ok
 in_geojson .. ok
 uninstall . /home/travis/build/robe2/postgis/regress/00-regress-
 install/share/contrib/postgis/uninstall_postgis.sql
 . ok (3857)
 Run tests: 91
 Failed: 3
 make[1]: *** [check] Error 3
 make[1]: Leaving directory `/home/travis/build/robe2/postgis/regress'
 make: *** [check] Error 1
 The command "make check RUNTESTFLAGS=-v" exited with 2.
 GEOGRAPHY
 GEOGRAPHY
 <#1320>
 @@ -210,7 +200,6 @@
 #1596.3|3395
 #1596.5|3395
 #1596.7|0
 #1596|Point[BGS]
 #11|0
 t
 #44|t|t
 #58|220187|150406|220289|150507
 ERROR: lwgeom_to_gml2: 'CurvePolygon' geometry type not supported
 #66|CIRCULARSTRING(0 0,1 1,2 2)
 #68a|MULTIPOINT(1 3,4 5)
 ERROR: lwgeom_longitude_shift: unsupported geom type: CircularString
 #69|CIRCULARSTRING(220269 150417,220228 150507,220228 150408)
 #70|3
 #73|GEOMETRYCOLLECTION(CIRCULARSTRING(1 1,2 3,4 5,6 7,5 6))
 #80|MULTILINESTRING((0 0,1 1))
 #85|0
 #116|POLYGON EMPTY
 #124a|COMPOUNDCURVE(CIRCULARSTRING(0 0,1 1,1 0),(1 0,30
 5),CIRCULARSTRING(30 5,34 56,67 89))
 ERROR: incontinuous compound curve
 #145a|0103000020E610000000000000
 #145b|0
 #146|0|t|GEOMETRYCOLLECTION(LINESTRING(0 0,-1 -1),MULTIPOINT(1 2,2 3))
 ERROR: Invalid hex string, length (267) has to be a multiple of two!
 #157|ST_Polygon|POLYGON
 #157|ST_Point|POINT
 #157|ST_CurvePolygon|CURVEPOLYGON
 #157|ST_CircularString|CIRCULARSTRING
 #168|3|MULTIPOLYGON ZM (((4275341.96977851 259186.966993061
 1323.76295828331 -1.79769313486232e+308,4275341.96977851 259186.966993061
 1323.76295828331 -1.79769313486232e+308)))|IllegalArgumentException:
 Invalid number of points in LinearRing found 3 - must be 0 or >= 4
 #178a|0
 #178b|5
 #179a|
 #179b|
 #210a|
 #210b|
 #213|17
 #241|0
 #254|010700000000000000
 #259|
 #260|1667701
 #261|0
 #262|POINT(-119.5434 34.9438)|t|t|t
 #262|POINT(-119.5452 34.9442)|t|t|t
 #262|POINT(-119.5438 34.9443)|t|t|t
 #263|SRID=4326;POINT(-119.5434 34.9438)|t|t|t
 #263|SRID=4326;POINT(-119.5452 34.9442)|t|t|t
 #263|SRID=4326;POINT(-119.5438 34.9443)|t|t|t
 #271|t
 #272|-2|2
 #277|<gml:Point><gml:coordinates>1,1e+308</gml:coordinates></gml:Point>
 #299|2
 #304
 #304.a|21
 #304.b|1
 #408.1|f
 #408.3|f
 #457.1|POINT(0 0)
 #457.2|LINESTRING EMPTY
 #457.3|POLYGON EMPTY
 #457.4|POINT EMPTY
 #457.5|LINESTRING(0 0,1 1)
 #457.6|POLYGON EMPTY
 #457.7|POINT EMPTY
 #457.8|LINESTRING EMPTY
 #457.9|POLYGON((0 0,1 0,1 1,0 1,0 0))
 #835.1|POINT EMPTY
 #835.2|LINESTRING EMPTY
 #835.3|POLYGON EMPTY
 #835.4|POINT EMPTY
 #835.5|LINESTRING EMPTY
 #835.6|POLYGON EMPTY
 #835.7|POINT EMPTY
 #835.8|LINESTRING EMPTY
 #835.9|POLYGON EMPTY
 #835.10|MULTIPOINT EMPTY
 #835.11|MULTILINESTRING EMPTY
 #835.12|MULTIPOLYGON EMPTY
 #650|MULTIPOINT(0 0,1 1,2 2)
 #667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.9999999999999,30
 40))
 #677|1121395
 #680|01d107000000000000000024c000000000000049400000000000000040
 #681a|
 #681b|
 #681c|
 #681d|
 #681e|
 #681f|
 #681g|
 #682|0103000020E610000000000000
 #683|0103000020E610000000000000
 #684,#2109|SRID=4326;POINT EMPTY
 #2109|SRID=3395;POINT EMPTY
 #685|0103000020E610000000000000
 #686|0107000020E610000000000000
 #687|f
 #689|f
 #690
 010200000003000000F771D98DE33826C00000000000004440F771D98DE33826C000000000008051400000000000805140F771D98DE33826C0
 #693a|0103000060E61000000100000005000000EA95B20C71C851C02B1895D409204540000000000000F03F9CC420B072C851C0C7BAB88D062045400000000000000840B1506B9A77C851C08E75711B0D20454000000000000000C0FF21FDF675C851C0F2D24D6210204540000000000000F03FEA95B20C71C851C02B1895D4092045400000000000000000
 #693b|0103000060E61000000100000007000000EA95B20C71C851C0AA605452272045400000000000000000386744696FC851C04703780B2420454000000000000034408638D6C56DC851C04703780B2420454000000000000034C08638D6C56DC851C0E3A59BC42020454000000000000014408638D6C56DC851C08048BF7D1D20454000000000000010409CC420B072C851C04703780B242045400000000000001840EA95B20C71C851C0AA605452272045400000000000003E40
 #694
 ERROR: Shell is not a line
 #695
 ERROR: First argument must be a LINESTRING
 #696|010F000080060000000103000080010000000500000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000010300008001000000050000000000000000000000000000000000000000000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F0000000000000000000000000000000000000000000000000000000000000000000000000000000001030000800100000005000000000000000000000000000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F0000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000000000000000000000000000000000001030000800100000005000000000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000010300008001000000050000000000000000000000000000000000F03F00000000000000000000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F00000000000000000103000080010000000500000000000000000000000000000000000000000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F000000000000F03F000000000000F03F0000000000000000000000000000F03F000000000000F03F00000000000000000000000000000000000000000000F03F
 #720|MULTIPOINT(-1113194.91 4838471.4,-1113194.91 7326837.72,-1113194.91
 11028513.63,556597.45 4838471.4,556597.45 7326837.72,556597.45
 11028513.63,2226389.82 4838471.4,2226389.82 7326837.72,2226389.82
 11028513.63,3896182.18 4838471.4,3896182.18 7326837.72,3896182.18
 11028513.63,5565974.54 4838471.4,5565974.54 7326837.72,5565974.54
 11028513.63)
 #723|0101000020E61000006284F068E33826C00000000000004440
 #723|0107000020E610000000000000
 #723|0101000020E61000006284F068E33826C00100000000804B40
 #804|<gml:Point srsName="urn:ogc:def:crs:EPSG::4326"><gml:pos
 srsDimension="2">0 0</gml:pos></gml:Point>
 #845|t
 #834|GEOMETRYCOLLECTION(POINT(0 0 5),LINESTRING(10 10 5,10 0 5))
 #884|1|f
 #884|2|t
 #938|
 #668|BOX(10 2,14 2)
 #711|
 #712|t
 #756.1|t|t
 #1023|t
 #1023.a|f
 #1023.b|t
 #1060|FFFFFFFF2
 #1273|t
 #1273.1|t
 <#1320>
 #1320.geom.1|MULTIPOLYGON|4326
 ERROR: Geometry type (Polygon) does not match column type (MultiPolygon)
 #1320.geog.2|MULTIPOLYGON|4326
 #1320.geom.2|MULTIPOLYGON|4326
 #1320.geog.3|MULTIPOLYGON|4326
 #1320.geom.3|MULTIPOLYGON|4326
 </#1320>
 #1344|25
 #1385|
 #657.1|-166.78
 #657.2|10.00
 #657.3|t
 #1305.1|POINT(10 10)
 #1305.2|t
 #1305.3|t
 ERROR: MultiPolygon cannot contain MultiPoint element at character 8
 ERROR: MultiLineString cannot contain MultiPoint element at character 8
 ERROR: MultiPoint cannot contain MultiPoint element at character 8
 ERROR: CompoundCurve cannot contain MultiPoint element at character 8
 ERROR: MultiCurve cannot contain MultiPoint element at character 8
 ERROR: MultiSurface cannot contain MultiPoint element at character 8
 #1453.1|t
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2467#comment:1>
