[postgis-tickets] [PostGIS] #2476: Invalid access to memory location in postgis-2.0.dll (windows 64-bit) 9.3 rc1
PostGIS trac at osgeo.org
Mon Sep 9 18:28:30 PDT 2013
rc1
 Reporter:  robe          |       Owner:  dustymugs
     Type:  defect        |      Status:  new
 Priority:  medium        |   Milestone:  PostGIS 2.1.1
Component:  raster        |     Version:  2.1.x
 Keywords:  windows64bit  |
Changes (by robe):
  * owner:  pramsey => dustymugs
  * component:  postgis => raster
Old description:
> this is the same error I was getting during install that magically went
> away. I'm getting this on some raster tables.
> "POSTGIS="2.1.1dev r11897" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel.
> 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24"
> LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER"
> error getting which is only on access to certain raster tables (MA state
> plane meters)
> An error has occurred:
> ERROR:  could not load library "C:/Program
> Files/PostgreSQL/9.3/lib/postgis-2.1.dll": Invalid access to memory
> location.
> What is very bothersome is that I'm only having this issue on my 64-bit
> windows 7 laptop.  I'm going to try a newer build to see if the problem
> goes away. My windows 7 is running postgis 2.2.0 dev.  The tables in
> question are ones that I couldn't load from file because it GDAL_DATA was
> not set though I verified it was set and then on last file for load it
> would crash raster2pgsql with same message.  My next attempt was to
> restore from my postgis 2.2.0dev build but tables when accessed then gave
> same message.
New description:
 "POSTGIS="2.1.1dev r11897" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0,
 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 plane meters)
 location.
 same message.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2476#comment:1>
