[postgis-tickets] [PostGIS] #2477: st_exteriorring on multisurface gives linestring
PostGIS trac at osgeo.org
Thu Sep 12 11:29:45 PDT 2013
  Reporter:  mjurce   |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.5
 Component:  postgis  |     Version:  2.0.x
Resolution:  invalid  |    Keywords:
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => invalid
  * milestone:  => PostGIS 2.0.5
Comment:
 Not sure I agree. The WKT BNF indicates that the rings of a CurvePolygon
 can be *any* of LineString, CircString or CompoundCurve.
 <ring text> ::=
     <linestring text body> |
     <circularstring text representation> |
     <compoundcurve text representation>
 In this case, the multi-surface text you've defined has a LineString outer
 ring, why not return that?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2477#comment:1>
