[postgis-tickets] [PostGIS] #2697: ST_GeomFromGeoJSON() of invalid GeoJSON Polygons crashes server process, possibly corrupts shared memory
PostGIS trac at osgeo.org
Thu Apr 3 11:25:44 PDT 2014
 Reporter:  kochb    |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 When trying to ST_GeomFromGeoJSON certain invalid geojson strings, the
 server process crashes and forces other clients to disconnect.
 Though this is certainly errant geojson, I would expect any error
 generated by a query to not affect unrelated server connections.
 '''To Reproduce'''
 Open two psql connections.  In the first, run the following query:
 test=> SELECT
 ST_GeomFromGeoJSON('{"type":"Polygon","coordinates":[1,1]}');
 You should receive the following error:
 SSL SYSCALL error: EOF detected
 The connection to the server was lost. Attempting reset: Failed.
 In the second, run any query:
 test=> \dt
 WARNING:  terminating connection because of crash of another server
 process
 DETAIL:  The postmaster has commanded this server process to roll back the
 current transaction and exit, because another server process exited
 abnormally and possibly corrupted shared memory.
 HINT:  In a moment you should be able to reconnect to the database and
 repeat your command.
 '''Version Info'''
 Postgres version: PostgreSQL 9.3.3 on x86_64-unknown-linux-gnu, compiled
 by gcc (Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit
 PostGIS full version: POSTGIS="2.1.1 r12113" GEOS="3.4.2-CAPI-1.8.2 r3921"
 PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24"
 LIBXML="2.7.8" LIBJSON="UNKNOWN" RASTER
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2697>
