[postgis-tickets] [PostGIS] #2672: ST_AsTWKBAgg fails NULL crash test
PostGIS trac at osgeo.org
Sat Apr 5 11:42:06 PDT 2014
  Reporter:  robe     |       Owner:  nicklas
      Type:  defect   |      Status:  reopened
  Priority:  blocker  |   Milestone:  PostGIS 2.2.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 strk seems to have run into the issue again -- strk comment on this one if
 you have confirmed you are running the latest and its still happening to
 you.  Otherwise close.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2672#comment:4>
