[postgis-tickets] [PostGIS] #2093: Add extra policy argument to control ST_Simplify behavior
PostGIS trac at osgeo.org
Sat Apr 5 12:56:02 PDT 2014
 Reporter:  robe         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by srstclair):
 GeoTools now has the ability to use ST_Simplify when rendering tiles from
 PostGIS. The polygon nullification behavior wasn't expected and caused a
 bit of a debugging headache:
 http://jira.codehaus.org/browse/GEOT-4737
 This behavior basically prevents ST_Simplify's use in map tiling
 applications. As strk mentioned above, using ST_SimplifyPreserveTopology
 isn't an option since it's usually much slower than just returning the
 original geometries. So, +1 for adding policy control argument(s) to
 prevent nullification of polygons.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2093#comment:10>
