[postgis-tickets] [PostGIS] #2703: KNN gist with recheck for 9.4?
PostGIS trac at osgeo.org
Sat Apr 5 23:09:13 PDT 2014
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
 I noticed this feature is on the commitfest 9.4 block for consideration.
 https://commitfest.postgresql.org/action/patch_view?id=1367
 Would be cool if we can push it along and leverage it in 2.2.  As best I
 understand it, it would mean our KNN would act as a true distance check.
 From patch thread
 KNN-GiST provides ability to get ordered results from index, but this
 order
 is based only on index information. For instance, GiST index contains
 bounding rectangles for polygons, and we can't get exact distance to
 polygon from index (similar situation is in PostGIS). In attached patch,
 GiST distance method can set recheck flag (similar to consistent method).
 This flag means that distance method returned lower bound of distance and
 we should recheck it from heap.
 Am I missing anything here?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2703>
