[postgis-tickets] [PostGIS] #2706: ST_DumpPoints crash
PostGIS trac at osgeo.org
Mon Apr 7 03:55:40 PDT 2014
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:
Component:  postgis  |     Version:  trunk
 Keywords:           |
 From garden test:
 SELECT ST_DumpPoints(foo1.the_geom) As result
 FROM ((SELECT ST_GeomFromText('POINT EMPTY',4326) As the_geom
 UNION ALL SELECT ST_GeomFromText('MULTIPOINT EMPTY',4326) As the_geom
 UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON EMPTY',4326) As the_geom
 UNION ALL SELECT ST_GeomFromText('LINESTRING EMPTY',4326) As the_geom
 UNION ALL SELECT ST_GeomFromText('MULTILINESTRING EMPTY',4326) As the_geom
 ) ) As foo1 LIMIT 3;
 Crashes the backend.
 Dunno which versions are affected, is to be tested.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2706>
