[postgis-tickets] [PostGIS] #2707: Setup winnie and debbie to run nightly garden tests
PostGIS trac at osgeo.org
Tue Apr 8 22:15:39 PDT 2014
 Reporter:  robe       |       Owner:  robe
     Type:  task       |      Status:  new
 Priority:  medium     |   Milestone:  Management 2.0
Component:  buildbots  |     Version:  2.1.x
 Keywords:             |
Comment(by robe):
 Having difficulty getting debbie to do garden.  I think My make install
 step is failing and not sure why.  Might be a permission issue.
 Just gives:
 {{{---- Making check in extensions
 make[1]: Entering directory
 `/var/lib/jenkins/workspace/postgis/branches/2.2/extensions'
 Nothing to check
 make[1]: Leaving directory
 [: 60: Illegal number:
 and the .so file never appears in pg install folder.  And of course garden
 fails with:
 CREATE FUNCTION
 ERROR:  could not access file "$libdir/postgis-2.2": No such file or
 directory
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2707#comment:1>
