[postgis-tickets] [PostGIS] #2710: correct script install for topology instructions
PostGIS trac at osgeo.org
Wed Apr 9 21:27:19 PDT 2014
 Reporter:  robe           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.6
Component:  documentation  |     Version:  2.1.x
 Keywords:                 |
 As noted by jamo in mailing list
 "The script locations
 appear to be wrong for the topology scripts - those scripts are just
 located
 in the /share/contrib/postgis-2.1 directory now, not under /topology (at
 least on my machine)."
 http://postgis.net/docs/manual-2.1/postgis_installation.html#create_new_db
 I think we changed the path in 2.0 to be right in same folder (not have a
 subfolder as it had in 1.5 and below)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2710>
