[postgis-tickets] [PostGIS] #2712: ST_Segmentize exception on Empty input: getPoint4d_p: point offset out of range
PostGIS trac at osgeo.org
Fri Apr 11 20:06:34 PDT 2014
range
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.3
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 This is similar to #2108
 When I run below on:
 SELECT postgis_full_version() || ' ' || version();
 POSTGIS="2.1.2 r12389" GEOS="3.4.2-CAPI-1.8.2 r3924" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8"
 LIBJSON="UNKNOWN" RASTER PostgreSQL 9.3.4, compiled by Visual C++ build
 1600, 64-bit
 SELECT ST_Segmentize('LINESTRING EMPTY'::geometry, 0.5);
 I get
 ERROR:  getPoint4d_p: point offset out of range
 Would seem to me that this should just return back a LINESTRING EMPTY.
 Someone complained about a similar issue here:
 http://gis.stackexchange.com/questions/92552/postgis-error-getpoint4d-p
 -point-offset-out-of-range
 Though I wasn't able to replicate the issue with his data.  I will retry
 again.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2712>
